View OSPF statistics to analyze trends. You can also graph statistics for all OSPF packets transmitted by the switch.
- Select OSPFv3.
- Select Stats.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
| Name | Description |
| TxPackets | Shows the count of sent packets. |
| RxPackets | Shows the count of received packets. |
| TxDropPackets | Shows the count of sent, dropped packets. |
| RxDropPackets | Shows the count of received, dropped packets. |
| RxBadPackets | Shows the count of received, bad packets. |
| SpfRuns | Shows the count of intra-area route table updates with calculations using this area link-state database. |
| LastSpfRun | Shows the count of the most recent SPF run. |
| LsdbTblSize | Shows the size of the link state database table. |
| BadLsReqs | Shows the count of bad link requests. |
| SeqMismatches | Shows the count of sequence mismatched packets. |
| Routes | Shows the number of OSPF routes added to the routing table. |
| Adjacencies | Shows the number of existing adjacencies. |
| Areas | Shows the number of configured areas. |
| Nbrs | Shows the number of OSPF neighbors. |
